GMs new Warranty
Discussion in 'The Coffee Shop ~ Chit Chat' started by ChevyFan, Feb 8, 2007.
  1. ChevyFan
  2. ChevyFan
    It actually says "courtesy transportation" which I guess is a loaner vehicle. Anyone know?
  3. ChevyFan
    NEW VEHICLE LIMITED WARRANTY
    GM vehicles registered in the U.S.A. are covered for 3 years/36,000 miles (whichever comes first). The complete vehicle is covered, including tires, towing to your nearest Chevrolet dealership and cosmetic corrosion resulting from defects. Repairs will be made to correct any vehicle defect, and most warranty repairs will be made at no charge. In addition, rust-through corrosion will be covered for 6 years/100,000 miles (whichever comes first) and powertrain will be covered for 5 years/100,000 miles (whichever comes first). See dealer for details.
    CORROSION PROTECTION
    Chevrolet vehicles are designed and built to resist corrosion. All body and sheet metal components are warranted against rust-through corrosion for 6 years/100,000 miles (whichever comes first). Application of additional rust-inhibiting materials is not required under the corrosion coverage and none is recommended. See your Chevrolet dealer for terms of this limited warranty.
    ASSEMBLY
    Chevrolet vehicles and their components are assembled or produced by different operating units of General Motors, its subsidiaries or suppliers to GM worldwide. We sometimes find it necessary to produce Chevrolet vehicles with different or differently sourced components than originally scheduled. Since some options may be unavailable when your vehicle is assembled, we suggest you verify that your vehicle includes the equipment you ordered and that, if there were changes, they are acceptable to you.
    ENGINES
    Chevrolet products are equipped with engines produced by GM Powertrain or other suppliers to GM worldwide. The engines in Chevrolet products may also be used in other GM makes and models.
    AN IMPORTANT NOTE ABOUT ALTERATIONS AND WARRANTIES
    Installations or alterations to the original equipment vehicle (or chassis) as distributed by General Motors are not covered by the General Motors New Vehicle Limited Warranty. The special body company, assembler, equipment installer or upfitter is solely responsible for warranties on the body or equipment and any alterations (or any effect of the alterations) to any of the parts, components, systems or assemblies installed by GM. General Motors is not responsible for the safety or quality of design features, materials or workmanship of any alterations by such suppliers.
    5-Year/100,000-Mile Powertrain LIMITED Warranty
    In addition to the standard 3-year/36,000-mile (whichever comes first) New Vehicle Limited Warranty, all 2007 Chevy vehicles come with a 5-year/100,000-mile (whichever comes first) Powertrain Limited Warranty that:
    • has a $0 deductible
    • is transferable to another owner at no charge
    The Powertrain Limited Warranty is in addition to the express conditions and warranties described in the Warranty Booklet. The coverage and benefits described in the booklet under "New Vehicle Limited Warranty" are not extended or altered because of this special Powertrain Limited Warranty.
    WHAT IS COVERED
    In addition to the bumper-to-bumper coverage described in the Warranty Booklet, General Motors will warrant each 2007 Chevy passenger car, light duty truck or van for 5 years or 100,000 miles, whichever comes first, from the original in-service date of the vehicle, against warrantable repairs to the powertrain components of the vehicle. The Powertrain Limited Warranty covers repairs to correct any vehicle defect related to materials or workmanship occurring during the 5-year/100,000-mile term for the following:
    Engine
    • Emissions control system components that are identified in the Emission Warranty Parts List within the Warranty Booklet
    • Cylinder head and block
    • All internally lubricated parts
    • Manifolds
    • Timing gears and timing cover
    • Timing belt (until the first scheduled maintenance interval)
    • Flywheel
    • Oil pump/oil pump housing, water pump and fuel pump
    • Harmonic balancer
    • OHC carriers
    • Valve covers
    • Oil pan
    • Engine mount
    • Seals and gaskets
    • Turborcharger or supercharger
    Transmission/Transaxle
    • Case
    • All internal lubricated parts
    • Torque converter
    • Transmission/transaxle mounts
    • Seals
    • Gaskets
    Front-Wheel Drive
    • Final drive housing
    • Axle shafts and axle shaft bearings
    • Constant velocity joints
    • Wheel bearings
    • Supports
    • Front hub bearings and rear-axle hub bearings
    • Seals and gaskets
    • Universal joints
    • Locking hubs
    • Front differential actuator
    Towing
    Towing is covered to the nearest Chevrolet dealer if your vehicle cannot be driven because of a warranted defect. Contact the Chevrolet Roadside Assistance Center for towing. Refer to the Warranty Booklet for details.
    Courtesy Transportation
    Interim transportation may be available under the Chevrolet Courtesy Transportation program if your vehicle requires warranty repairs. Please refer to your Owners Manual for details or consult your dealer.
    WHAT IS NOT COVERED
    As the vehicle owner, you are responsible for the performance of the scheduled maintenance listed in your Owner’s Manual. In addition to the “What Is Not Covered” section of the Warranty Booklet, this Powertrain Limited Warranty does not cover the following items:
    • Powertrain wear items, such as clutch linings
    • Wear items, such as brake linings
    • Scheduled maintenance items, such as filters, coolants and fluids, and brake pads/linings
    • Any damage caused by owner/lessee failure to follow scheduled maintenance may not be covered by warranty
    • Damage due to accident, misuse, alteration or contaminated or poor quality fuel
    NOTE: Interim maintenance, checks, inspections, and recommended fluids and lubricants as prescribed in the Owner’s Manual are necessary to keep your vehicle in good working condition.
    Hybrid Warranty
    SILVERADO HYBRID WARRANTY INFORMATION
    For vehicles sold in the United States, in addition to the bumper-to-bumper coverage described in the Warranty Booklet, General Motors will warrant certain Hybrid components for each Chevrolet Silverado Hybrid for 8 years/100,000 miles, whichever comes first, from the original in-service date of the vehicle, against warrantable repairs to the specific Hybrid components of the vehicle. The Hybrid Component Warranty is in addition to the express conditions and warranties described in the Warranty Booklet. The coverage and benefits described in the Warranty Booklet under "New Vehicle Limited Warranty" are not extended or altered because of this special Hybrid Component Warranty. For Hybrid owners requiring more comprehensive coverage than that provided under this Hybrid Component Warranty, a GM Protection Plan may be available. See your Chevrolet dealer for more details.
    WHAT IS COVERED
    This Hybrid Component warranty covers repairs to correct any vehicle defect related to materials or workmanship occurring during the 8-year or 100,000-mile term for the following:
    • All automatic transmission components, including the auxiliary transmission fluid pump assembly, flexplate assembly, electric machine rotor and stator
    • Electrohydraulic power steering pump and reservoir
    • Brake-apply system sensor on the brake pedal assembly
    • Starter generator control module (SGCM)
    • SGCM radiator and fan
    • SGCM coolant pump and bottle
    • Energy storage box and components, including batteries and control module
    • Hood switch
    • Electric power outlets
    • Three-phase cable assembly
    • Hybrid control module
    • Towing to the nearest Chevrolet Hybrid servicing dealer is covered if your vehicle cannot be driven because of a warranted defect. Contact the Chevrolet Roadside Assistance Center for towing. Refer to the Warranty Booklet for details.
    • Interim transportation may be available under the Chevrolet or GMC Courtesy Transportation program. Please consult your dealer for details.
    WHAT IS NOT COVERED
    As the vehicle owner, you are responsible for the performance of the scheduled maintenance listed in your Owner’s Manual. In addition to the “What Is Not Covered” section of the warranty booklet, this Hybrid Component Warranty does not cover the following items:
    6.6L DURAMAX Diesel Engine Warranty
    For trucks equipped with the 6.6L Duramax Diesel engine, the complete engine assembly — including turbocharger components — is covered for defects in the material or workmanship for 3 years or 36,000 miles, whichever comes first.
    These engine parts continue to be covered for 5 years or 100,000 miles, whichever comes first:
    • Cylinder block and heads and all internal parts
    • Intake and exhaust manifolds
    • Timing gears
    • Timing gear chain or belt and cover
    • Flywheel
    • Harmonic balancer
    • Valve covers
    • Oil pan
    • Oil pump, water pump and fuel pump
    • Engine mounts, seals and gaskets
    • Diesel Fuel Metering System: injection pump, nozzles, high-pressure lines and high-pressure sealing devices
    • Glow Plug Control System: control/glow plug assembly, glow plugs, cold advance relay and ECM
    • Fuel injection control module, integral oil cooler, transmission adapter plate, left and right common fuel rails, fuel filter assembly, fuel temperature sensor and function block
    * Whichever comes first. See Dealer for details.
  4. Geeezzz
    Geeezzz New Member
    in the old days a company would put up a big warranty knowing they wouldn't have any claims, thus giving the consumer the feeling they are purchasing a good product, they're not gonna have any problems with... now a days it means, the company makes a competitive product, or just as good as the leading companies, but we'll fix it for free!..... with their track record since 1997 with coolant related gasket failures, it shouldn't take too long to see how it'll work out.
  5. rollingrock
    rollingrock New Member
    Yes, that's one of the reasons I bought my Canyon last month.
  6. patnick
    patnick New Member
    I just bought my 1500 HD w/ Quadsteer and the extra Warranty 5/100,000miles
    Costed me additiona $2535!!!! I think i got ripped!!!
  7. craig6970
    craig6970 New Member
    Ext warrenty
    I wish they had the 5/100,00 warrenty when I bought my 05 colorado. I bought the ext warrenty to go to 100K extra. Damn GM.
  8. z71guy
    z71guy New Member
    Purchased DaimlerChrysler Extended Warrenty
    Hey Guys,
    I have had my 2004 Z71 for about 8 months now. Bought it at 33000.
    I have 42,000 now and already the water pump went. Thanks to the 7/100 Added care plus contract it only cost $100. The repair job cost ~700 (Yikes).
    The plan cost $1700 when I bought the truck, it is well worth it. I had a 96 Tahoe before this and I also had the extended warrenty on that one.
  9. Cableguy
    Cableguy Epic Member 5+ Years ROTM Winner 1000 Posts
    It's good to see GM step up again to the warranty plate. Company I work for had a huge contract with them (and had to move to Ford because of it)
    Warranty is a big selling point for any car company nowadays.
    I'm still eye-balling an 07 Trailblazer SS...
  10. TrailLeadr
    TrailLeadr Epic Member 5+ Years 1000 Posts
    It's been four years. You're due.
    Go get it!!:biggrin::biggrin:
