going to look at a 2004 silverado...problem areas to look for?
Discussion in 'General Chevy & GM Tech Questions' started by CMS, Nov 22, 2011.
  1. CMS
    CMS New Member
    Im going to look at a 2004 Silverado 1500 extended cab 5.3L with 93,000 miles. what area or areas should i focus on the most? Like what are the known problem areas and signs of the problem and how to check for it. This would be my first silverado purchase if i decide to go ahead with the deal if everything checks out alright. I want to go there with a good sense of knowledge on this truck so i guess any bit of info would be of help and appreciated. thank you
  2. ChevyFan
    maintenance is the #1 issue. How many miles? How many services? Oil changes and the maintenance done by the books? That's key to keeping it running w/o any mechanical issues.
    Otherwise, not much breaks down in these things, little things only really.
    ---------- Post added at 10:05 PM ---------- Previous post was at 10:00 PM ----------
    Is this from a dealer or a small lot or a private party? Try to get as many receipts as possible for maintenance if you can get them.
  3. CMS
    CMS New Member
    Its sitting at a small lot so i already know the dealer is going to tell me everything i want to hear to make a sale and thats why i wanted to really go prepared
  4. jbjones240
    jbjones240 Rockstar 100 Posts
    They have a recall on the a/c regulator/module. I have to look at my paperwork to give the exact description but factory dealers will cover it for you.
    -JJ
  5. gear_head
    gear_head Member
    Can you explain this a bit more or provide a link?
  6. TRPLXL2
    Common problems I have came across in my last 3 Silverado's, two of them being 05's and one 04'.
    Intermediate steering shaft (knocking noise which can be cured by lubing procedure, or replacement with upgraded Borgeson shaft)
    Gauge Cluster stepper motors (solution is to solder yourself, or send it out for $179)
    4x4 actuator (common malfunction, expensive If you can't do yourself)
    HVAC problems (blower motor/resistor)
  7. 99'HEARTBEAT
    As mentioned above the 2003" to 2007" Trucks/SUV's have problems/Issue's with the....Blower Motor Resistor's.....But G.M. Does Have a Special Coverage Adjustment.......the Coverage Adjustment is on the Vehicles/Years I've mentioned above and it is for.......10 YEARS or 150,000 MILES(240,000km).....whichever occurs first, from the Date the Vehicle was Originally Placed into Service.......Regardless of Ownership, the Repair will be made at No Charge to the Customer.
    Edit:......I'll add one more item and that is......an Issues/Problems with the Front Wheel Hub Bearings.
  8. SurrealOne
    Don't sweat the intermediate steering shaft issue if you encounter it. There's a thread in the HOW-TO section of this very forum that resolves it and it's a 10-15 dollar fix (parts) if you have the tools, already.
  9. TRPLXL2
    I can't count on both hands how many times I did the lubing procedure on that shaft, It's a waste of time and money. Just turn your radio up and you'll get used to the knocking noise, even the Borgeson shaft doesn't work for some people also noted in said thread that Darcy posted on here.
  10. SurrealOne
    Remove the intermediate shaft exactly once, remove all old grease (soas not to mix grease types), cut and tap a hole, replace the intermediate shaft, screw a zerk fitting into the hole that was tapped, pump 60-75ish shots of grease into it ... give it a few hundred miles to get where it needs to get ... and then any time the knocks come back just give it a few more shots of grease with a grease gun (without any additional disassembly and consuming practically no time).
    Page 2 of the thread dealing with intermediate shaft lubrication covers that approach. (http://www.gmtruckclub.com/forum/sh...ermediate-Steering-Shaft-Lube-Procedure/page2) Simple and cheap -- and it saves lots of time. Gotta love it.
