Got my Rockstars on finally!
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by HawaiiKid, Jun 11, 2010.
  1. HawaiiKid
    HawaiiKid Rockstar 4 Years 500 Posts
    Here they are :)
    I love the way they look. They are 20x8.5s, wrapped in Aurora 285/50R20s :party:
    Also, heres a pic to show what it looked like before the rims were on it.
  2. Pats1pab1
    Pats1pab1 Rockstar 4 Years 500 Posts
    Really change the look of your truck, real nice!!
  3. j-schmizzle
    j-schmizzle Rockstar 4 Years 1000 Posts
    way to go. now you can party like one!!!!:great:
  4. murdog94
    Nice looking rims...
  5. mus99gt
    mus99gt Rockstar 100 Posts
    Those chrome Rockstars look really good on your truck!!
  6. Eddie Z71
    They look great! Nice choice on those! Thanks for the pictures!:glasses:
  7. Kman1022
    Kman1022 New Member
    They look great man! Have been thinking about those on my truck too. Not sure If I want the black or chrome. Thinking more the chrome though. Have you noticed much of a loss in mpg since you went up a few inches in rim height?
  8. 04-silverado
    04-silverado Rockstar 100 Posts
    It isn't "overall height" of the TIRE (plus the RIM) which affects *ACTUAL/TRUE* MPG... although changing that "overall height" can cause errors when trying to calculate MPG.
    If you significantly oversize or undersize (from original mfg specs) your tires+rims, your odometer (and speedometer) will be out of calibration. As a result, there will be a corresponding error if/when you try to calculate MPG (based on an erroneous reading of MILES from your odometer, divided by the number of gallons consumed)... and your speedometer reading will also be erroneous. So...
    If you significantly oversize or undersize (from original mfg specs) your tires+rims ... and the "overall height" is changed as a result... then get your system recalibrated, so that your speedometer (and thus your odometer) will be reading correctly. It is the "overall height" of the TIRE plus the RIM to which you need to pay attention, when buying different sized RIMS and/or TIRES.
    Reputable retailers will advise you against changes (in "overall height") if/when you seek to purchase their products. Then again; there are those out there, who will sell you anything, just to make a PROFIT. So to be on the safe side... double-check their advice BEFORE "plus" or "minus" sizing. Do some comparisons of "overall height") for the TIRE + RIM to which you are considering a change... using this online calculator:
    It could save you headaches, and/or a few bucks (in avoiding a speeding ticket, or two).
    later edited to add:
    For example, I recently purchased a new set of tires from an online source. I used the LINKED REFERENCED which I provided above, to do a "comparison".
    First I completed the Vehicle Stock Tire Size section, using 235/75R16 (per original MFG specs).
    Then, in the Compare Tire Sizes section, for Tire Size 1: I input 245/75R16 (for the "General Grabber HTS" tire which I was considering). I could have INPUT additional tire sizes to be compared, but elected not to do so.
    Lastly, I clicked the Compare Tire Sizes button.​
    The results indicated that if I changed TIRE size, that my speedometer would be off a tiny bit, as follows: Speedometer Difference: 1.977% too slow -- not really significant... as that would mean with 100 MPH showing on my speedometer, I would really be doing 102 MPH on a calibrated "radar gun" ... hardly enough to warrant a ticket... unless the SPEED LIMIT happened to NOT be 100 MPH! :na:
    This also meant that my odometer would be OFF as well, thus giving an erroneous indication if/when I chose to calculate MPG. Had I elected to also change RIM SIZE, the differences would have been calculated for me, when I input the TIRE size with which I wanted to go (when compared with the original/stock specs).
    ...just my 2cents
  9. HawaiiKid
    Thanks, I love these rims...they really have changed the way the truck looks. As far as mileage goes, I havn't seen much of a difference. I went on a 350 mile trip this weekend, and gas consumption seemed pretty normal.
  10. Kman1022
    Kman1022 New Member
    Great info and link. Saved it for future use. Thanks man!
