Grease points??
Discussion in 'Chevy C/K Truck Forum' started by pino55, Oct 5, 2010.
  1. pino55
    pino55 New Member
    1988 silverado k1500
  2. cobra2end
    cobra2end Rockstar 100 Posts
    whats the question?
  3. pino55
    pino55 New Member
    Would like to know all the grease points for my truck. 88 silverado / 5.7
  4. cobra2end
    Its been a lil bit scene i been under one of the older Chevys i think the is any where from 8 to 14 depending on the truck that year i think has eight but not todaly sure. check the tie rod ends inner and outters the upper and lower ball joints. drive line and u joints. the pitmen arm and the idler arm.
  5. 2COR517
    Upper and lower ball joints, both sides = 4
    Inner and outer tie rod ends, both sides = 4
    Pitman arm at center link = 1
    Idler arm at center link = 1
    Idler arm bracket = 1
    Front driveshaft slip yoke = 1
    That's 12 so far.
    If you have a two piece rear driveshaft, there is another slip yoke.
    Check your u-joints for grease fittings. Two joints for the front shaft, two or three joints for the rear shaft. Some u-joints have fitting, some do not. Check all the joints individually. It's not uncommon to have different joints on either end of the driveshaft.
    If you have a two piece rear shaft, I can't remember if the center support has a grease fitting.
    Use good quality grease. I use Mobil 1 full synthetic. Great quality, plus it's a pretty color......
