Great green globs of greasy grimy gopher guts
Discussion in 'General Chevy & GM Tech Questions' started by Dr_Zero, Mar 15, 2009.
  1. Dr_Zero
    Great green globs of greasy grimy gopher guts mutilated monkey meat dirty little birdie feet that is kinda what I found when I went to clean out from under the suburban :lol:
    I happened to notice some mud build up so went through a car wash that is supposed to clean the undercarriage. Well when I looked up under there was mud and clay caked in places a good couple of inches thick :gasp:
    So I got down there and used a brush to start but then finally had to just soak the stuff and eventually melt it off, man it was nasty!
    Its a good idea to avoid rust and a clean drivetrain will run cooler and last longer.
    So the question is how many people ever take the time to clean off the underside?
  2. adidasboy918
    adidasboy918 Epic Member 5+ Years 500 Posts
    I try to when I have the time but atthe same time I'm not around mud that much.
  3. ct9a
    Hmm, maybe I should take a peek. I haven't washed my truck once since I got it.
  4. bry2500
    I just find the deepest puddle I can.:lol:
  5. Z71_guy
    i usually take it to a self clean wash and use the power wash on the underbody
  6. Dr_Zero
    LOL you guys are a trip
    I have tried all of the above but never noticed how the body panels cup under to trap so much stuff, mud sand and road grime had accumulated and was rock hard.
    Even if one does mostly paved road driving there is a oils from leaking cars and gravel that gets slung up under there and it gets nasty some Simple Green or Purple Power or Greased Lightning will help to get rid of the greasy build up that attracts other gunk.
    I'm working on the rear end next I have a stiff nylon toothbrush style brush to clean out the nooks and crannies.
    After its all done I'm going to clean and touch up any spots that may have some surface rust.
    So far its all good no body rust and some superficial near the rear bumper going to fix that and would like to do the frame rails with some POR but I'm not that adventurous yet LOL
  7. tbplus10
    I have a small Karcher pressure washer (2200 PSI) I use on the undercarriage everytime I wash my vehicles, it only takes an extra 10 minutes.
    Dont usually run my trucks through mud so it's mostly dust and road debris, the wifes HHR actually picks up more debris than my trucks.
  8. Jimmiee
    I'll second the car wash. The one I go to cleans better than anything I could do at home. We have salt here in Reno so I go to the car wash every time they salt the roads.
