Halo Projector Headlights
Discussion in 'Chevy Truck Accessories' started by Corins, Jan 15, 2010.
  1. Corins
    Corins Member
    Does anyone know how to hook up the wiring for these things, its really only for the halo itself that's a problem, there are 4 wires coming from the housing (2 white 2 red) all 4 go into a small black casing and then on the other side of the casing there is 2 wires coming from it, I have no idea where to put these, plus they are both red in color. You can see by the picture what I'm talking about.
  2. Corins
    Corins Member
    Ok I got them hooked up and working, however when I added HID's for the low beam and took it for a drive, the lights are pointed at the ground even with the adjuster screw trying to point the lights to the sky. Any ideas how to fix that?
  3. TRPLXL2
    First off what type of vehicle are these on, and is it stock height or lifted or lowered. The reason I ask is because I had a set of projectors on a lifted Silverado, and from trying to adjust them so far down I actually broke the adjuster in half. The only way I knew this was to open the headlights up, and I had to physically had to take apart the projector to see that they had snapped in half. I replaced mine with a longer adjuster, and after that they worked beautifully.
    Here is a link to the thread I wrote about those headlights, you don't have to go through the whole thing but scroll down about half way on the first page and you will see the comparison of adjusters and just how bad there design was. Hope this helps, and I am glad to hear that you got them wired up!
    http://www.gmtruckclub.com/forum/showthread.php?t=22659
  4. dsrtne1
    dsrtne1 Epic Member 5+ Years 100 Posts
    Amy (TRPLXL2) is the queen of aftermarket lighting. I've learned that its way easier to just ask her directly than start a thread :lol:
  5. Corins
    Corins Member
    I have it all figured out, took a bit of messing around with it, but its working like it should.
  6. TRPLXL2
    Alright well that's good to hear you got it straightened out, just thank your lucky stars that you didn't have to do what I had to do to fix mine. :party:
  7. rotaryenginepete
    rotaryenginepete Rockstar ROTM Winner 100 Posts
    could also have been that the HID bulb wasn't aligned properly in the socket, causing a stigmatism in the projector beam. i had that problem when i first converted mine. had to make a small cut for the D2S bulb to fit in there properly and not all crooked. even the ones with adapters for different kinds of bulbs will sometimes not line up correctly. i've done a lot of HID installs and this happens often with projectors...
