Head unit wont shut off
Discussion in 'Audio, Video & Gadget Tech' started by castor, Jul 4, 2011.
  1. castor
    castor New Member
    I have an 03 silverado with a JVC double din head unit, I bought the correct harness to wire everything up. As you all know it has the RAP and also as you know as soon as you open one of the doors it shuts off. Well when I got home just now from work, i turned the truck off and removed the key and opend the door but the head unit didnt shut off. I started the truck and shut it off and opened the door several times but to know avail. I ended up having to pull the fuse under the hood.
    I need some help, so anyone that has any ideas throw em at me.
    Thanks,
    Tim
  2. sstoner911
    The power button doesnt work on the unit to turn it off?
    Sometimes the door switch needs to be replaced and thats why your radio wont shut off. It should be in the door latch assembly. Do the interior lights work properly?
  3. castor
    castor New Member
    Yeah oddly enough they do. which side is the switch on?? Like on the actual door or where the body of the truck is??
    What can I do to combat this till I can get a switch??
    Thanks,
    Tim
  4. sstoner911
    You have to take the door panel off...you will know it when you see it..kind of like a round cylinder i believe with 2 wires coming off it. You can jump the wires to see if it will shut your radio off...if it does its the switch.
  5. castor
    castor New Member
    thanks alot for the info. I appreciate it.
    Tim
  6. silveradotrailblazer
    Welcome to the club, Tim.
  7. castor
    castor New Member
    thanks for the welcome
  8. sstoner911
    No problem, keep us updated.
  9. castor
    castor New Member
    Does anyone know about how much these switches go for usually?? can I get one at like autozone or advance?? or do I have to order it from a gm dealer??
    Thanks for (more) info
    Tim
  10. sstoner911
    I would think you could get one from autozone for that year....shouldnt be to pricey.
