Headlight replacement
Discussion in 'Chevy Truck Accessories' started by thejms, Feb 9, 2009.
  1. thejms
    thejms Rockstar
    I am looking at getting new headlights and taillights for my 2002 GMC Sierra. The sun has taken its tole on them and they are hazing over.
    I like the look of the projectors and LED's. I found a couple on ebay and parts train, but not sure if anyone has had any good/bad experiences with these types of units?
    What is a good recommended replacement?
  2. Springthing
    Have heard a lot of good, some bad. For the projector lights you just need to find what you like and make sure the look is what you want. A few people on here have put projector lights on and taken them off after a short while. They just didn't like the looks of them. I have two vehicles with projector lights and I like the light pattern I get with both, personally.
    The LED taillights certainly add some ZING to the look of the truck, overall. Again you have to look around and find what fits with the style you are going for. If you have a jacked-up, big tired, black brushguard on dark pewter truck with black rims and black nerf bars... well, the chrome alezza (spelling?) taillights probably are going to look totally crappy and throw off the whole look of the truck!
    I say look around the forums, maybe go to the photo albums and look around them all (you'll find a link on the top right to visit the Photo Gallery) and when you get an idea of what you are looking for you can have a look around.
    Headlights and taillights are extremely simple to swap out, normally. Not much experience necessary.
  3. thejms
    thejms Rockstar
    Thanks for the advice, I just wanted to make sure that people didnt have leaking/condensation problems and stuff like that with different brands.
    I have had those type of problems with other vehicles and it is quite frustrating to have a new headlight look like there is a sauna inside of it!:lol:
  4. FocuzTech
    FocuzTech New Member GMTC Sponsor
    You would be surprised...even some of the best OE lamps have condensation issues...venting is the key.
  5. 05azsilver
    05azsilver Rockstar 100 Posts
    I have heard more problems with condesation on OEM lights than aftermarket. Go figure.
  6. thejms
    thejms Rockstar
    Wow that could be annoying
  7. Springthing
    If you want to ensure (or help prevent as much as possible) the moisture issue I was told to do two things.
    The first is sticking the assemblies, on wet towels, in your oven on the lowest setting for 10 minutes or so, I think. Taking the assemblies out with gloves on, press the lens to the housing. This is supposed to help soften the glue and help smoosh it more to lessen gaps.
    Following that take to the gap of the housing/lens with caulking/gasket sealer. Just run a bead all along he edge, then press the bead into the gap and smooth is down so you have one good continuous seal.
    If you are proficient with google, give a quick search around for some key words and I'm sure you'll be able to find the information to which I am referring.
    Good luck!
  8. thejms
    thejms Rockstar
    I did something similar to one of my car that I was having this problem with. The outcome wasnt satisfatory. I had condensation after that as well. Turns out it was the seal of the bulb area (supposedly).
    I'll just have to try my luck and post my experiences!:happy:
  9. 2008blackWT
    2008blackWT Rockstar
    I have seen guys spray the reflectors in silver. It actually looks really uniform. Goes well with the chrome housing. These guys that i have seen do that are using paint that you mix up and put in a paint gun. Reason being is they are thinning it out so it will stil look some what reflective and see threw.
  10. thejms
    thejms Rockstar
    That sounds pretty interesting! My original problem was the hazing of the plastic, the outside part. That is why I was looking at getting a replacement. I have wet sanded headlights before, it turns out ok for a short time. Just ALOT of work though.
