Headlights always on ?
Discussion in 'Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)' started by nutlug, Jul 3, 2012.
  1. nutlug
    nutlug New Member
    I just picked up a 97' Tahoe and the headlights are on most of the time , even with the switch is off. It looks the same as my 95' K2500 , but I'm trying to figure out if there is a problem in electrical system or what ? Why would there be a off switch if you can't turn them off ? Thanks , Steve
  2. Pikey
    Those are considered driving lights. They are on for safety. You will notice that your tail lights do not turn on unless you turn the switch to on. I am not positive about that year, but you may be able to press the dome light/overide button quickly 4 times and it might shut them off.
  3. nutlug
    nutlug New Member
    The dome switch did not work, but I found out that if you tap the emergency brake they go out.
  4. Kady
    Its normal, Its the daytime running lights. I had a 96 Suburban, did the same thing. There is a way to bypass it, if you don't mind the little green indicator light on in the dash... I don't remember if we pulled the fuse or did something with the bulb, but you can get around it. The dome override switch only works on the 00 and up.
