Headlights won't TURN off. Help!
Discussion in 'GM Electrical Tech' started by billetman, May 31, 2011.
  1. billetman
    billetman New Member
    Hey everyone.
    In my 99 silverado my headlights will not turn off. Daylight or night time they will not shut off. They will shut off if I apply the parking brake so I have eliminated that part of it.I have tried pushing the dome override button four times and that didn't make any difference. I recently got ahold of a manual and it does troubleshooting with a gm scanner tool. I dont have a scanner or access to one. I was wondering if anyone else has had this problem, and if so how was it fixed? I tore the dash apart today and didnt find any loose connections as I could see. Starting with the simple stuff. any suggestions of what maybe it would be? would be greatly appreicated.
    Thanks,
    Billetman
  2. KyleZ71
    You have tried using the little turn nob at the dome over-ride button right?
  3. Jimmeh
    Dumb question, but is there something covering the little sensor on your dash? If there is something covering it, your headlights will automatically come on since it will think it's dark. Here is a picture from the outside of the truck of the sensor I am talking about in my dads 99 Silverado:
    [​IMG]
    I had a receipt covering the one in my truck and my lights were on constantly. And my old company truck I drove at my old job was missing that sensor completely, so the lights were constantly on. Just a thought.
    kennythewelder likes this.
  4. billetman
    kylez71, yeah ive tried the knob at the override button, didnt make any difference.
    jemmeh, theres nothing covering the sensor, I had the dash tore apart yesterday and I could see the wire that plugs into the sensor. It had a good connection from what I can see. I didnt get to carried away with taking the dash apart so I couldnt see where that wire lead to.
    Thanks
    Billetman
  5. 59diesel
    59diesel New Member
    Looking at your headlight issues. Did you ever figure it out? I have a 99 Sierra with the same issue. Soon as you turn on the key and start it, lights on day or night, and I CAN NOT figure it out. The DRL do not work at all, have good bulbs, sensor is hooked up, not covered with anything.....anyway, I know its been a while with yours but figured Id ask........
  6. loudpipes
    loudpipes New Member
    The lights do go out when you turn the key off don't they? I am experiencing same thing with mine. My Impala has the lights on in daytime also but can be turned off with override position.
  7. xPosTech
    xPosTech Epic Member 5+ Years 1000 Posts
    I think I'd first check the relays controlling the lights. See if the relays have good inputs for ground and 12V (by good I mean 12V across coil when on and no voltage when off). More probable is stuck output contacts. Some relays that pull high current will actually weld the contacts together.
    If you find a relay that was just stuck and after messing with it seems to work, replace it. It will fail again.
    Ted
  8. RayVoy
    Hey Ted, my first thought was a stuck relay, but that would keep them on all the time. These go on and off with the key.
    I'm leaning towards either daytime running being on, or maybe the ambient light sensor thinks it's always dark.
    OP, by any chance, do you have a hat, or book covering the dash mounted light sensor?
    xPosTech likes this.
  9. xPosTech
    Hard to tell Ray. Especially with three guys with similar but slightly different symptoms. None said if they owned the truck and problem cropped up or if they had just bought the truck. All over a five year span.
    Some guys attempt the all six on high mod and have less than ideal results and just live with it till they sell the truck. It's also a symptom most buyers won't ever think to check when looking at a truck to buy. The seller probably won't volunteer the info out of the blue.
    It'll take some time under a tree with a test light or, preferably, a meter.
    I think maybe the OP turned his lights off for good.
    Ted
    RayVoy likes this.
  10. wmrcarr3
    wmrcarr3 New Member
    My 2000 GMC Sierra does the same thing no running lights just head lights... They did work when new... I can turn them off by pushing three times on the dome light override button But still daytime running lights... I can't be sure the dash sensor works... Is there more than one relay?
    I have checked the relay by the steering column... With no luck... Any suggestions will be appreciated
