Headlights
Discussion in 'Audio, Video & Gadget Tech' started by herritage, Nov 17, 2008.
  1. herritage
    herritage New Member
    I have a 97 Chevy Silverado. The headlights come on when the ignition is turned on as is supposed to. However, when you turn the headlight switch to the on position, the headlights go off. In the parking light position they stay on. Can you help?
  2. 04sierracrewcab
    have you checked the fuses,relays,wires ect. ??
    hope fully we can help you get this resolved :great:
  3. retired
    retired Rockstar 100 Posts
    I'm thinking you have a bad headlight switch. If the headlights going on in the parking position.
  4. herritage
    I have checked fuses and wiring. I even replaced the switch. However, the switch was from AutoZOne and someone told me that switch may also be bad.
  5. herritage
    On this model the headlights come on when ignition switch is on (running lights). My truck they go off when the headlight switch is turned to the on position. When turned to the park light position they remain on.
  6. Thundare
    Thundare Rockstar 100 Posts
    Sounds Like A HeadLight Lamb Prob, Lamb have like three modes on them, try to replace em and see what happonds
  7. Crawdaddy
    could it be the daytime running lights? I'm not sure why they would go off when you turn the switch on, unless it's a blow fuse somewhere in the chain. The DRLs and headlights have 2 separate fuses. I want to say the headlights are on fuse A or B for some reason, but I could be wrong. Check your manual.
