heard somethin weird the other day
Discussion in 'Lifted & Offroad Suspension' started by Eslingerj, Sep 22, 2009.
  1. Eslingerj
    Eslingerj New Member
    i heard that they were puttin nitrogen in tires to keep them colder does that give you a better ride or just save your tires
  2. Loggerhead Mike
    the only purpose for nitrogen is so ppl dont have to adjust there tire psi as often
    nitrogen molecules are bigger than oxygen thus they wont leak down as much
  3. wrightj
    wrightj Member
    so would you recommend putting nitrogen in?
  4. MOJ06
    MOJ06 Rockstar
    I run all my tires with Nitrogen. I highly recommend it.
  5. hamhock
    hamhock New Member
    How do you fill them? Do you keep a bottle of nitrogen around?
  6. ahmitchell1
    A few of my buddies work at Kauffman tire and if u request it they will fil your tires with it. they do it the same way
  7. tbplus10
    This is pretty much the only reason to run nitrogen, the pressure doesnt fluctuate as much.
    Aircraft tires are serviced with nitrogen to keep pressures steadier when going between extreme cold and heat cycles.
    We used nitrogen in our truck tires in the gulf so we wouldnt have to service the tires every morning, the temperature can fluctuate as much as 60deg between day and night.
