Hello there
Discussion in 'Member Introductions' started by KroBaar, Jun 25, 2010.
  1. KroBaar
    KroBaar New Member
    Just a quick hello from Saskatoon, Saskatchewan, Canada. I have a 2007 Chevy Classic Silverado Crew Cab 1500 4x4 Z71. Just going to take a quick peak for any info on replacing brake shoes
  2. swedp
    swedp Rockstar
    hi,what are the problem?
  3. 99'HEARTBEAT
    :sign0016:To the Site....:glasses:
  4. KroBaar
    KroBaar New Member
    The problem at the time was trying to figure out how to deal with the bottom "spring" on the brake shoes. I've only ever dealt with an '89 Chevy (my old truck) so this one was a bit new, but I finally just used some force with some water pump pliers and got it going. Now after doing all my brakes (did the front ones yesterday, new pads and turned the rotors, had the drums turned today), my brakes are super soft. I have enough fluid and they don't feel spongy like you'd expect if there was air in the lines (I never opened any lines, so not sure how that would happen anyway). I have to pretty much put my foot to the floor before it starts braking. Trying to figure out if I somehow missed something.
    By the way, yes I realize that moisture/dirty brake fluid will cause weak brakes, but what is confusing me is the brakes had better pressure with the old worn out brakes than they do now with the new pads/shoes. Actually, tested the brakes after replacing the front pads and it was fine, it has only been since I replaced the shoes. I've braked several times in reverse as I'm pretty sure that is how the shoes self adjust. I will most likely flush the system anyway, just confused right now. Maybe I didn't hook the self adjusting mechanism properly and it's not adjusting? Will have to try and google for some pictures, but when I was changing the shoes, I did one side at a time and tried to make sure everything looked the same as the other side that was not changed. Any thoughts anybody?
  5. retired2001
    Welcome to the GMTruckClub!
  6. Eddie Z71
    Hi, and welcome to the site!
  7. murdog94
    Welcome aboard.
  8. vnslykrx
    vnslykrx Rockstar
    Welcome!!!
