Help 96 suburban k1500 stuck in 4 wheel drive
Discussion in 'GM Powertrain' started by Pmont, Aug 5, 2010.
  1. Pmont
    Pmont New Member
    Stuck in 4 wheel drive no lights on switches and I tried changing out new switches and still nothing what should I do?
  2. DAREDEVIL
    There is a shift seliniod on the 4x4 box at the tranny, i bet its a loose wire..or fuse ,or the seliniod is bad..check it ..once u find it u will know what to do ..
  3. murdog94
    X2.. common fault on these old trucks...
  4. KyleZ71
    If its electrical, try pushing 2wd, disconnect the negative cable from the battery, and then connect it again. Hope it helps
