Help!!! Charging system!!!
Discussion in 'Audio, Video & Gadget Tech' started by pmf608, Jan 7, 2009.
  1. pmf608
    Sorry - I know I'm multi-posting, but its urgent!
    URGENT!!! I need the truck to move tomorrow.
    Tonight, my charging system display in my 2001 Silverado 1500, 4.8L would randomly come on for a few seconds, and I'm scared it could be a serious problem. If anyone could help, that would be great.
    Here's the rundown:
    - Message center would show charging system light
    - fuel gauge & temp. gauge would drop to 0
    - Automatic gear indicator would turn off (gears would show, but not that I was in drive)
    - Voltage gauge stayed constant (around 15ish - a little high, but it seemed ok)
    - NO electronics dimmed, failed, or malfunctioned, other than instrument cluster
    - power brakes and steering still worked
    - No changes in how the engine ran
    - only accessories on were heater, auto dim mirror, and HID headlights
    - at one point, the entire instrument cluster went into the startup test, with all lights on (airbag, brake, etc.)
    What I've figured out:
    - It shouldn't be my new HID's (first drive with them) because it happened with standard high beams on
    - Drive belt on alternator appears OK - its old but its in a good enough shape
    - Alternator seems to be spinning...
    - This DID NOT happen at all while at a stop or idleing.
    I REALLY NEED THE TRUCK TOMORROW, as I'm moving, so if anyone could help me out, it would be great. Thanks in advance.
  2. Big_Blue
    Big_Blue New Member
    The only place your lacking juice is the dash?
    Sounds like a circuit breaker problem or an intermittent ground
  3. pmf608
    Thanks. I think it could be something to do with the instrument cluster, because all gauges, lights, accessories, etc. were fine except the message center, gear indicator, fuel gauge, and temp gauge
