HELP! Fog Lamp Install Gone Wrong
Discussion in 'Lighting Discussion' started by cjt28, Aug 1, 2012.
  1. cjt28
    cjt28 New Member
    I bought the fog lamp kit from GM Parts Direct. Took quite sometime to get everything installed, but i was careful with each step. Problem is the lamps do not turn on when the button is pushed. Attached are pictures of the directions I followed and a picture of the block connector indicating where I installed the wire for the fog lamps.
    Has anyone has this problem besides me? If, please point in the right direction. Also, i checked fuses and everything looks fine. I think the problem may be I have the wire look in the wrong place?
    UPDATE: PROBLEM RESOLVED - HAD TO REVERSE THE WIRE TO THE OPPOSITE SIDE OF THE BLOCK CONNECTOR.
