Help guys with black trucks ~ truck cleaning
Discussion in 'Detailing & Truck Care' started by groceryman, Sep 7, 2011.
  1. ntbush83
    Thats it??! Wow I've always thought it took longer for some reason. Well awesome! May just have to do it one day this week! :)
  2. 89steveo50
    89steveo50 Rockstar
    I've heard turtle wax and mcguires are normally the top brands. I"ve only used cleaner wax and haven't gone into the polish/ wax.
    My question is... Is it best to hand wax it all and clean it off with a towel, or do you guys recommend buying a polish and the whole 9 yrds with it? I got a black truck, and i really reall want the dark rich wet black tone to it.
  3. pray1140
    pray1140 New Member
    Go Big or Go Home !! I would take it the whole 9 yrds. I have done it both ways and seem to be much happier with the result after the polish!
  4. silveradotrailblazer
    Claybar, polish and wax. Smooth as a baby's butt!:lol:
    X2 on what STB has mentioned.....After I Wash my Truck.....I then do a Clay Bar.....which is a Must before applying a Polishing Compound and Wax.
  6. groceryman
    groceryman Rockstar ROTM Winner 100 Posts
    wax.jpeg Turned out pretty good thanks for the help guys
  7. AA1PR
    AA1PR Rockstar 100 Posts
    I only wax the yukon with traditional turtle wax once in the spring and once in the fall before winter. throughout the summer i use the turtle wax ice, it is ever so simple, spray it on wipe it around, turn the terry cloth over and buff. I do the windows, chrome and everything with this. I am disabled and for the 15 minutes or so it is all I can tolerate & I get excellent results.
  8. Dylan@Adams
    Dylan@Adams Member 100 Posts
    Bringing an old thread back from the dead here, but figured some things needed to be clarified.
    The first thing to understand is that its more about the process than it is about the products. Sure a quality product will make the job easier, faster, or yield better results, but in the end its WHAT you do and HOW you do it that will address your paint issues.
    Polishing is the only way to remove swirl marks, and it almost always requires a machine if you want to get 100% correction... its a numbers game really. A polisher like the porter cable 7424xp osciallates at up to 6800 times per minute. No matter how much coffee you drink you will never ever ever be able to move your hand at that rate and keep a consistent and even application of pressure on the applicator to make any real meaningful change. The rule is that you can get a marked improvement by hand, but for 'perfect' you need a machine.
    If you simply looking to hide the problems temporarily then there are products out there like the black box and filler/glazes that will help hide the swirls, but the problem is that with just a few washes or a few days in the sun the tinted fillers in those products begin to wash away or fade, leaving you back where you started.
    Also - WAXES DO NOT FIX SWIRL MARKS. This is a common misconception and usually one of the first thing suggested when someone asks for advice on forums 'how do I remove swirls?' Waxes are simply a coating to protect and enhance the paint, nothing more. It takes a polish to remove swirls.
    With the water spots, generally claying will handle the more mild ones, and you should clay before polishing anyways to make sure the paint is fully decontaminated. In some cases clay will only remove some of the water spotting, generally though whatevers left can be polished out with mild polishes and foam pads.
  9. ChevyFan
    In my quest for a new-to-me truck, I've been looking at a lot of black trucks. These are some good tips that I'll have to keep in mind.
