Help on lift questions for 99 sierra
Discussion in 'Lifted & Offroad Suspension' started by Ted Magda, Feb 9, 2012.
  1. Ted Magda
    Ted Magda New Member
    Hi i got a 99 gmc sierra 2500 6.0 (new body style). I was wondering What kind of smaller lift can i get without spending 2 grand for a suspension lift. or is that my only option. I put a 2in block in the rear and turned my torsions all the way up in front. Any other way to raise it? thanks
  2. 99'HEARTBEAT
    ***Thread Moved To Lifted/Off-Road Suspension Section for the Forum***
  3. Burden33
    Did you swap out your torsion keys for aftermarket ones and you could do a body lift
  4. aloxdaddy99
    [MENTION=53328]Ted Magda[/MENTION]- How high do you want to go? Is it to fit a certain size tire? You could go with a body lift or new torsion keys.
  5. Ted Magda
    No i didn't swap torsions just turned the ones i had now to lift 1 1/2 inches and blocks in back. i got 285/75/16's now. would like to go bigger if possible. would new torsions lift it higher?
  6. IPFK83
    IPFK83 Rockstar 3 Years 100 Posts
    Yes by buying a torsion key lift you will gain another inch or two, but keep an eye on all of your tie rod angles if you go this direction.
  7. rileyjr16
    I heard that you can go up with a spindle lift. I know you can go down with one but I'm also sure you can go up with one.
