HELP on S-10 missing
Discussion in 'Chevy S10 Forum (GMC Sonoma)' started by jstforfunn, Sep 28, 2010.
  1. jstforfunn
    jstforfunn New Member
    Good comp. wires firing, spark plugs new. Could it be one of the injectors not injecting correctly, Has a miss and is running on 3 cyl. on ldle and driving. Oh it is a 2.2 help me.
    Or should I just put a TPI motor in and get it over with. lOL.
  2. murdog94
    Need year and make... to tell you more since there are several versions of the 2.2L in the S-10
  3. jstforfunn
    s-10 it is a 1995
    It is a 1995 s-10 that has just been sitting now for a month.
  4. murdog94
    Timing chain been done? also how about the head? since the 95s were notorious for head gasket and head problems. also yes you may have a problem with the injectors (im not realy sure on the process for checking them)
  5. coreyallen11
    coreyallen11 Rockstar
    ive heard of disconnecting the wiring from the injector and taking a 9 volt and 2 wires and you should hear a click if its good and nothing if its bad not sure on it but its a thought
  6. Quad racer#212
    Quad racer#212 Rockstar
    Sounds like the ignition control module. Its a shot in the dark but i would look into it.
