Help Please: How to remove front bumper part and rear bumper corners -- 09 silverado
Discussion in 'General Chevy & GM Tech Questions' started by mjs84, Dec 28, 2010.
  1. mjs84
    mjs84 Rockstar
    Hello all -- looking to have a few parts powder coated but am unsure on how to remove them. Does anyone know how to remove the front bumper top and rear bumper corners on a NNBS silverado?
    Front bumper piece: link here
    Rear bumper corners: link here
    Thanks --
  2. mjs84
    mjs84 Rockstar
    Any tips guys? Thanks
  3. Bigbomber
    Have you climbed underneath and taken a look to see if you can find the bolts?
  4. canislupis69
    MJ, for the front bumper here is a link to Zone's 1.5" body lift instructions
    They will walk you through how to take the front bumper off. Once the front end is off, there are a whole bunch of small bolts holding the bumper itself to the front end (this whole thing was a PITA!...and I had to do it twice, once to install the bl and the second to have the bumper powder coated).
    As for the rear corners, if you go under the truck you will see release tabs for the plastic step pieces on top. Once you get those off (another PITA!) you will notice the corners are actually on with rivets. I drilled the rivets out and bought stainless steel bolts and nuts and used those to reassemble once I got the corners back from powder coating. Hope this helps!
  5. mjs84
    mjs84 Rockstar
    Thanks this does help -- Glad that a simple powder coating job has turned into a PITA! Will make a big difference though...
  6. canislupis69
    Yeah, it is worth it in the end.
