Help! Really soft steering.
Discussion in 'General Chevy & GM Tech Questions' started by HolySloth, Dec 27, 2010.
  1. HolySloth
    HolySloth New Member
    Recently purchased a '99 K1500 Burb. On city streets it feels great, but when you get up to highway speeds you can really feel the softness in the steering.
    In other words, if you hold the steering wheel in place on a straight stretch, it will drift to one side or the other in a fairly dramatic fashion. You really have to use two hands on the wheel (I know, I should do that all the time anyway) and pay a lot of attention to keep it in the lane. And I end up weaving a bit anyway, kind of like its really windy...when it's not.
    And when I'm driving over the pass if I turn the wheel to corner it takes a moment to respond. I can turn the wheel an good distance before it responds.
    Is this just an alignment issue or do I have something more serious going on here?
    Thanks fellas,
  2. stephan
    Welcome to the GM truck club Dan. This sounds like either excessive free play in the steering, or it could also be too much toe out. If it's steering, it is either in the steering itself or the tie rods ends. If you want to check this yourself, have someone turn the wheel left/right while you lay under the front & watch the tie rods & everything else that moves. If you can't see any obvious play, then while you're under there you should carefully examine your front tires. Are they more worn on the inside edges than the outside?? If so, this would indicate too much toe out, which will also also cause waundering & needs to be addressed professionally.
    Got snow in Bend ???
  3. HolySloth
    Ok. I'll check that later today. Wife has the truck today.
    We had a LOT of snow earlier this month! But it's warning up and pretty much gone. However I got to drive the pass to the valley four times in the last week, so the snow was pretty impressive on the roads up there.
    How far west are you?
  4. stephan
    Really far lol. w.s.w. of Roseburg & n.n.w. of Grants Pass. If you find a bad tie rod end on your burb, post back here & I can walk you through the replacement & setting your toe in.
    If you have NO play anywhere in the steering, then it's just toed out too far & is an easy fix to set it.
