Help starting issue!
Discussion in 'Performance & Fuel' started by FireRed, Apr 5, 2009.
  1. FireRed
    FireRed Rockstar 100 Posts
    Hi drove my sub out to my buddies yesterday to got over to CT for an over nighter, jumped in this afternoon it spins over like crazy does a very brief start and die sequence. As soon as I turn the key it does the same thing over and over, I checked all the fuses that I think are related. I do hear the fuel pump do it initial pressure up which allows it to try to start but N/G! Any and all ideas very much appreciated as it is sitting in my buddies driveway!
  2. johnsstart
    johnsstart Rockstar 100 Posts
    Sounds like two things if you hear the fuel pump firing then i would check the fuel filter might be clogged. If that turns out good id start checking for firing issues plugs wires coils or distributer cap. Hope that helps but i would def start with the fuel filter if you have never changed and dont know when it was last serviced no gas no crank. :glasses:
  3. FireRed
    Thanks for your input, checked a bunch of stuff then asked my local mechanic, he said it was a security system issue. He was spot on, I went out and did the few things he said to do and it started fine and all is back to normal. He said I would be surprised how many shops would have put a fuel pump in or various other things to fix a non existing problem, sure is nice having an honest mechanic!!!
