Help!!! Third Row Seat Stuck!
Discussion in 'General Chevy & GM Tech Questions' started by DavidNJ, Jun 4, 2009.
  1. DavidNJ
    DavidNJ New Member
    I don't use it much and put it in over the weekend. All looked good until I tried to take it out.
    Apparently the cargo area floor mat is under one of the three rear clevises, between the clevis and the rod. The other two clevises are clamped, the third appears closed.
    Neither lever one nor lever two will operate. If I pull up on the seat lever one moves a little, but seat back only rocks forward a little. The carpet won't pull out.
    Is there a way to manually disengage this without using the levers? Is there a way to trick it?
    HELP!!! I need my load bed back!.
  2. DavidNJ
    DavidNJ New Member
    Used a large crow bar and an aluminum floor jack in the back to slightly pry up the seat. It still required a strong two hand pull to remove the carpet. Afterwards the seat engaged, and lever one, the lever 2, and pull 3 worked. An interesting anomoly where the interlock of the levers left the seat in an unsecured state that was only obvious when you tried to remove it.
  3. KidHauler
    Glad to see you got it resolved. The thickness of the mat must have tweaked the seat frame when you slammed it in to place last time.
  4. DavidNJ
    DavidNJ New Member
    No, just had the floor mat between on clamp and the floor. It was pinching the mat but not closing. The other two were closed. Lever two wouldn't work until lever 1 let the seat fold flat. And lever 1 wouldn't work unless all three clamps were closed.
  5. daddytech
    went through the same thing in my wife's 98 suburban. not a fun time at all specially when you are in a hurry to get on the road. glad you got it taken care of though , it really is just a muscle it out kinda deal though. that's what worked for me, didn't use a crow bar just brut strength and determination
  6. bry2500
    Did the same in the wifes Toyota Sienna. I was able to unlock each latch while my nephew pryed up to keep them from relatching.
    Glad you got it out.
  7. route66paul
    route66paul Member
    Now that it is out, you should make sure that the mats or carpets are where they are meant to be, you might want to use a silicon spray, or even wd40 to free up these latches. When they get stuck, the force needed to get them unstuck can bend the rods and ruin the hardware. Be sure to check the action BEFORE you click it into place, because these latches are hard to work with bad hardware and springs.
