HELP! Tire pressure sensors
Discussion in 'Wheels & Tires' started by mxracer919, Jun 16, 2009.
  1. mxracer919
    mxracer919 Rockstar
    Ok, so I traded my 08 for a 09. Pulled the aftermarket 20's off and put the stockers back on(left the 08 sensors in the aftermarket wheels. So I put the 20's on the 09 and I get a code that shows the flat tire and says service the tire pressure monitor system. Can I get them to work by going through the reset process outlined in the owners manual, or do I need to swith over the sensors from my 09? Anyone experienced this?
  2. Jimmiee
    I would check with GM parts and see if the sensors are the same part number. If they are the dealer or a good scanner should be able to reset the sensors so your PCM sees them. Keep in mind your ABS system won't work correctly until you clear that wheel speed code.
  3. Z71_guy
    any good tire shop should have a tool for them, we charge $20 to reset the TPMS sensors, but make sure they are the same part number first
  4. grimreapersshadow
    grimreapersshadow Rockstar 100 Posts
    wow you charge to reset? maby thats what i need to start doin xD
  5. Z71_guy
    got to pay for the TPMS scanner some how
  6. mxracer919
    mxracer919 Rockstar
    i checked on a schrader website and found that the part numbers are the same for the 08 and 09. Couldnt find anything on 09 oem sensors. I plan on calling the dealer today and double checking.
  7. mxracer919
    mxracer919 Rockstar
    Talked to parts at gm and they said it was the same sensor. Then they transferred me to service and its $95 to get them reset! Goning to have to do some checkin before I do that.
  8. Greg84
    Greg84 Rockstar 100 Posts
    Can't you do it yourself? I did it on my trailblazer when I changed rims.. took 4 or 5 minutes tops. It said how to do it in the manual, get it in the programming mode and then let air out of each tire in a certain order and it beeps the horn after each one is recognized.
  9. 5speedsilverado
    thats kinda weird, but does sound like a good idea
  10. mxracer919
    mxracer919 Rockstar
    Been reading and it looks like I can, gonna give it a try......seems like it should be pretty easy. From reading on here and talking to the dealer it sounded like it had to be done by someone with a scanner.
