Hesitation at throttle tip-in
Discussion in 'Chevy C/K Truck Forum' started by PabstMaster, Jan 23, 2010.
  1. PabstMaster
    PabstMaster New Member
    My 93 K-1500 350 w/ 230,000 miles idles smooth but requires a lot of gas pedal to to start increasig revs, then comes on sharply. The engine has a mild lope that's more noticeable at low revs. It's particularly annoying while stuck in slow traffic or in parking lots, or other stop/start situations. Sometimes engine will stall after starting, but will start right back up.
    Does anyone know anything about this, or has anyone had this issue? Thanks for any help anyone can provide.
  2. silveradotrailblazer
    Have you removed the throttle body and cleaned the top and bottom. Also remove the IAC from the throttle body and clean it, the pintle gets carboned up and cant move in and out. Make sure you use throttle body cleaner and not carb cleaner.
  3. okysmokey911
    okysmokey911 Rockstar 100 Posts
    Cleaning the throttle body is a good idea, but it also sounds like you might have a timing problem.
  4. x1LSUTigerfan
    x1LSUTigerfan Member
    I had the same problem with mine it would surge power when trying to speed up and sometimes would die right after starting i changed my distributor cap and rotor , tps switch, and coolant temperature sensor, and it ran perfect after that and i have the same truck as you.
  5. Coolrado
    Coolrado Epic Member 5+ Years 500 Posts
    Sounds like the fix, I would also clean up you throttle body though. I have cleaned mine twice now at around 30,000 miles each time. It makes a pretty noticeable difference on my truck.
  6. x1LSUTigerfan
    Yea we changed my intake gasket at 200k and we cleaned all that up throttle body and junk
