Hey there all
Discussion in 'Member Introductions' started by tripmucoy, Aug 22, 2011.
  1. tripmucoy
    tripmucoy New Member
    He all. New to the sight. Need some addvice. I lifted my Tahoe way up now I feel under powered and im losing font berings cant seem to keep the front end together on it. I dont really off road very hard. I am just tired of being scared of doing another 180 on the highway wile cruzing along at about 65. So what can be done? I was thinking bigger motor swap and I'm not sure what to do about the front end.
  2. Crispyt
    Crispyt Rockstar 100 Posts
    When you lifted it did you make sure that all the drive and cv axle shafts are set right? Such as on the driveshaft, are the yokes set right so that when it spins its not vibrating alot? You could be chewing up bearings fast because if there individual bearings, and there not being set in right or packed right with grease is can cause problems. Is the bearing outter race good and not pressed in wrong so its not warped. If its a hub assembly make sure that its not a cheap one. Try a Timken one if your not already.
  3. mfleetwood
    Welcome to the club!! You may get more responses if you re-post your question on the Tech Q&A or Suspension part of this forum...you posted in the member introductions area. When you do post, it would be helpful to include additional information such as: type and height of lift, if you changed tire size vehicle year and other details, etc. For you loss of power concern, if you did increase tire diameter, then yes, your vehicle will be more sluggish. Re-gearing the rear end would help fix that.
  4. silveradotrailblazer
    Welcome to the club. When you say you lifted your Tahoe, what lift kit, how high, did you crank the torson bars, what size tire are you running and what year Tahoe??
  5. ChevyFan
    Welcome to the club. You'll have better luck breaking apart your questions and posting them in their respective forums on here.
  6. sgtsjj
    sgtsjj Rockstar 3 Years 1000 Posts
    welcome to the club!!!!!
  7. Bigbomber
    Welcome to the site!
  8. csltrains96
    csltrains96 Rockstar 100 Posts
