HID help?
Discussion in 'Lighting Discussion' started by GMCZ71, Dec 8, 2011.
  1. GMCZ71
    GMCZ71 Rockstar
    I just got HID's installed on my truck and the lights when I went to switch from low beam to high beam it took them a while to get bright...I have been doing some research and I can't figure out the best way to fix this(if its even possible)...any pointers will be a great help
  2. Burden33
    the only way to fix this is do a high four mod so when you hit your high beams your low beams are still on and your high beams will be too other then that you cant since hid need time to warm up since the halogen bulbs
  3. GMCZ71
    GMCZ71 Rockstar
    but i went to a car dealer in my area to see if the new cars did the same thing but they said they didnt...its just nerve racking when your goin down the road and when you switch from low to high you lose the road...i read that i can either but a small capacitor in the wiring or get a harness...has anyone done either of these things with results?
  4. SurrealOne
    That's because HIDs are not used for high beams in most (all?) new cars ... for the very reason you've encountered.
  5. Klutch Mclovin
    Klutch Mclovin Rockstar 100 Posts
    What type of HID's do you have? You probably got one of the cheaper sets of ballasts and bulbs. The more high quality HID's such as Morimotos and Densos have an almost instant warmup time.
  6. bama2010z71
    bama2010z71 Rockstar
    how do you do the 4 high mod. i wanna do it to my dads older body truck since i got him a set of hid's for christmas
  7. Burden33
    There is a thread in the how ro section i think it is for the hig 4 mod
  8. GMCZ71
    GMCZ71 Rockstar
    I got race sport hids...I talked to a couple different tech people and they said a wiring harness will cure my problem cause instead of drawing power through the wiring the harness draws its power straight from the battery so I'm goin to try that...it was only $30 for both high and low wiring harnesses so I'm gonna try that...thanks for the help guys...ill let guys know what happens when the harnesses get here
  9. GMCZ71
    GMCZ71 Rockstar
    Well I got the wiring harness but I think I blew my ballasts on the driver side cause now they don't work...how much are replacement ballasts and can I switch the kind of ballast I have for a different/better ones?(if there's a difference in them)
  10. sstoner911
    The ballasts themselves are suppose to get power directly from the battery.....I am not sure what setup you have but I dont have the problem you describe.
    My ballast draws power from the battery...stock head light plug connects to ballast..then HID from the ballast to the headlight.
