HID help?
Discussion in 'Lighting Discussion' started by GMCZ71, Dec 8, 2011.
  1. Klutch Mclovin
    Klutch Mclovin Rockstar 100 Posts
    You might have blown your bulbs.
  2. GMCZ71
    GMCZ71 Rockstar
    Well I figured out my problem...I just wired the harness wrong and it helped a lot...but they flash when they turn on and sometimes does it flashes a couple more times while they are warming up...is this normal?
  3. sstoner911
    I have never seen what your describing. When I start my truck the HIDs seem to come right on with no flashing....there is a warm up time for HIDs between 1-2 minutes generally so I wouldnt worry about what your seeing.
  4. Klutch Mclovin
    I don't quite know what your describing either. When I got my HID's I had to re-wire them because of the crappy wiring they did with them, but mine never flashed. It should start out dim and eventually get brighter in a minute or so.
  5. GMCZ71
    GMCZ71 Rockstar
    The flashing occurs when I first turn them on and when I swithch from low beam to high beam and vice verser...would better ballasts change anything cause I'm woundering now if the kit I got is a cheap kit...the brand is race sport and it cost $200 to have both high and low beam installed
