HID possibilities????
Discussion in 'Audio, Video & Gadget Tech' started by 84SilverBullet, Oct 10, 2008.
  1. 84SilverBullet
    84SilverBullet New Member
    i want to go with a 6000K HID system on my 84' C-10 but cant seem to figure out what bulb they are... i.e.(H4,H5...... and so forth) if anyone has a clue let me know!!! thanks
  2. TahoeFever
    TahoeFever Epic Member 5+ Years 500 Posts
    All you need to do is go to a auto parts store and find out what type of bulb you need to replace the headlight bulb ..for example mine is a 9006 and a 9005 low and high beams ..when u know that info then you can order a HID system kit cause it uses the same bulb type ...
  3. scooby2b2
    scooby2b2 New Member
    I don't think they make HID bulb kits for 84 with the glass bulbs since its all one unit instead seperate bul;b from lens like the newer ones are.
  4. Springthing
    Sounds like you are asking for something like this.
    If you are just wanting to know about the bulbs, then the above says it uses H4 bulbs.
    Your sealed beams need to be replaced with housings that are able to take the appropriate size bulb.
