HID Suggestions
Discussion in 'Lighting Discussion' started by HFD525, Jun 29, 2012.
  1. HFD525
    HFD525 Member
    I am going to be getting HIDs for my 2012 Silverado 1500 Lows Highs and Fogs. What do you suggest getting?
  2. Ridyn
    Ridyn Rockstar 100 Posts
    I went with 55W 5000K for my lows and 35W 5000k for my fogs,, they have the same color output, but the 55W are a brighter white. I don't like having the blue/purple ghetto junk so i went with something classy.
  3. PantheraUncia
    I just did 35w low beams and was told its not a good idea to do the high beams because there is a 3-5 second delay for the HID's to warm up when switching between high and low beams so you are with out any light long enough that the potential to wreck or hit something is there.
    Where did you get the 55w kit/ballasts from? I wanted to go 55w in the low beams but I was told that there are allot of problems with the 55w ballasts?
  4. Ridyn
    I get all my HID needs from ddmtuning.com and I've never had any issues with their kits. I got their slim digital ballast on my GTO and I got the regular raptor HID kits on my pick ups.
  5. BRB46
    BRB46 Rockstar 100 Posts
    I purchased mine,35w 5000k low beam from VVME. they were Hella ballasts and i also used a relay kit (which is highly recommended) that was all plug and play. X2 on the high beam unless you do a lot of rural driving as the constant on/ off cycle will shorten the life of bulb and ballast
  6. Kady
    I agree with Ridyn, I've always purchased my HID's from DDMtuning... I did though, have a problem with my fog light ballasts, they both seemed to go out, at separate times, but they have a life time warranty, so no biggie right? WRONG!!! I can't get through to any customer service agents to get my kits replaced.... Bummer.
  7. ffdsmokeeater
    ffdsmokeeater Member
    Ridyn,
    Is there a reason why you went with the slim ballast on the GTO and regular raptor on your pick-up (other than size)? I'm thinking about picking up two kits (low & fog).
  8. Ridyn
    It was purely because of the size, the GTO has plenty of room for the raptor ballasts, but I wanted to hide them very well in the GTO because I used it for car shows and just wanted a cleaner install. My truck, not so worried since it's not going to be used for show at all.
  9. ffdsmokeeater
    Ah, ok cool. I think I'm going to go with the slim ballasts for my truck anyway. Just to hid them even better. Did you opt for the recommended "two in two out" wiring harness for the 55 watt kit?
  10. Ridyn
    No I did not, I normally only purchase things that people have commented on using before so I didn't go with it.
