high mileage cleaning??
Discussion in 'Performance & Fuel' started by suburban2500, Nov 24, 2009.
  1. suburban2500
    suburban2500 Member
    ok guys heres what i need to know i have an 06 2500 with the 6.0 in it it was a worktruck so only the necessities were done what do you recomend i clean under the hood it now has 145,000 on it what needs to be cleaned and what do i use???? maf? iacv? throttlebody? sea foam? oil changes were done constantly and i put the new penzoil platinum in it says it cleans 46 percent of sludge should i still use a motor flush??? any tips to help any recomendations??? anything would be greatly appreciated thanks guys
  2. marine59
    marine59 Member
    engine cleaning good only on outside of engine on the inside use a good oil and FILTER i use lucas oil and stabalizer, i use a K & N oil and air filter, this will keep inside your engine in great condition, in winter i use regular valvoline oil, have put thousands of miles and NEVER a engine failure. keepit tuned up will help to keep carbon from aaccumilating on valve stems, you can pop a valve cover to see if there is any sludge in valve train, good luck but i would stay away from engine flushes ken
  3. vncj96
    just use quality products, you get what you pay for. i currently own 142k and 180k mileage vehicles and no problems, just do the correct maintainence and pay attention to what is going on in your vehicle. if you have a tach pay attention to it, temp gauge, pay attention to your mpgs every fill up, these 3 things are FREE tell tales that if something is going on in your vehicle they will be some of the first things effected. I do use seafoam every october and may in both vehicles though
