How do you tell difference-semi vs full floating rear azles?
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Bherr, Aug 22, 2013.
  1. GuyGene
    GuyGene Member
    Wait, you mean you have to remove axle just to change rear wheel bearing? Hey, I don't know much.
  2. steved
    steved Former Member
    Yup, even on a full floater...
    But on a semifloater, you pull the diff cover, pull the crosspin and spider gears (assuming an open diff), slide the axles in a tad to pull the c-clips, then pull the axles from the housing...a little more involved than a full float.
  3. 08silverado3500hd
    08silverado3500hd Rockstar 100 Posts
    On my 1990 Silverado 3500 and my Dad's 2000 LS 3500 you have to pull the axle to even get to the brakes. On the 1984 Scottsdale we always pulled the drum when rotating the tires to check the brakes/drum and give it all a good blast of air to clean out any dust. Since you have to pull the axle to remove the drum on the 1990 & 2000 pads are only checked through the inspection hole and drums are checked when the pads need replaced.
  4. Bherr
    Bherr New Member
    OK I replaced the wheel bearings with no problems, but still have the whining noise, which after further investing found the noise was coming from the differenial. so back to Advanced auto for bearings. Had to remove the axials again and the rear cover and drive shaft. Now I can't find out how to remove the differential shaft. Got all the guts out of the differential but can't seem to fine out how you remove the inner and outer bearings. Any body know the combination?
    Ben
  5. a.graham52
    a.graham52 Rockstar 100 Posts
    They press on and off. Is the noise load sensitive (more or less throttle) if it is then its probably just wear on the ring and pinion. Only way to cure that is to replace the ring and pinion.
  6. Bherr
    Bherr New Member
    a.graham,
    the truck has 287,500 miles and the noise is throttle sensitive. Seems the loudest at about 40 mph and goes away when letting off the throttle. So if it is the ring and pinion gear how do I remove the pinion? If I can remove the pinion then I also want to replace the inner and outer bearings while I have it torn down. I've got the ring gear out already and the yoke and seal is off.
    ben
  7. j cat
    to do this I would have had a transmission / drive train repair shop experienced with these vehicles do the pinion work. you have to properly adjust things and that takes experience also specific detailed info to make the proper adjustments.
    most of these vehicles do make a whine sound at the 40 MPH. if its not leaking I would just leave it alone.
  8. Bherr
    Bherr New Member
    l'm thinking about calling the local salvage yard & installing a whole new rear end. I'll just reinstall the new wheel bearings.
    Ben
  9. j cat
    if you use a salvage rear diff then that would be better .
