how much trans fluid/what kind should i buy for the 4l60e transmission in my 97 k1500
Discussion in 'GM Powertrain' started by Chrisakin35, Mar 16, 2012.
  1. Chrisakin35
    Chrisakin35 New Member
    its a 97 k1500 with the 4l60e(well, im insisting that it has it because how many 1500s have a 4l80e?) and 5.7l v8 and 200k miles
    anyway, im changing the valve body and putting a shift kit in my tranny because im throwing some codes and i dont feel like rebuilding this tranny right now and im trying to buy some time till i get my 383 s10 done in the next mointh or two. i am wondering how much trans fluid i should buy and what kind? also what kind of filter etc and how do i know if i have a deep pan or a shallow pan? im looking at this ish
    http://www.autozone.com/autozone/pa...KeyWord=transmission filter&fromString=search
    i need to do this soon as i am driving 50 miles away in about an hour and a half or 2 hours....
  2. Z71_guy
    you can use dex III or dex VI. VI is an updated fluid that replaced dex II and III, I believe that GM recommends this in all vehicles now
  3. Chrisakin35
    alright, how many quarts if im just doing a fluid change?
  4. Dana W
    You have a 4l60e if your pan has 16 bolts instead of 18 like the 4l80.
    For pan removal only it takes 5 quarts. For overhaul 11 quarts.
    Make sure to check your level for cold temp and then again for hot after refilling.
  5. Josh
    Josh Member 100 Posts
    i highly recommend a bottle of crc trans stop slip/leak/seal conditioner/etc etc. i did a fluid and filter change on my 94 4l60 and it shifted a lil better but was still shifting at the wrong times. some harsher than others. i bought this can prior because i wanted to know if there was a difference. came home sucked out i believe 3/4 of a quart and dumped in the crc. it instanly from the time i put it in gear all the way to this day it has shifted completely different. by different i mean perfect. no shifting too late/hard. occaisional slip in second. it all disapearred and has not returned. i used carquest brand DEX III with there profesional grade filter/gasket kit. im very happy with what i bought. ive been pulling my boat in this warmer weather with the shift controller on stage 1 and its shifted much smoother and quicker. it literally tuned my 4l. p.s. DO NOT OVERFILL THE TRANS. IT WILL SLIP ASK ME HOW I KNOW.
