How much weight can the third door/hinges handle?
Discussion in 'Chevy S10 Forum (GMC Sonoma)' started by Rolling7z, Aug 8, 2014.
  1. Rolling7z
    Rolling7z New Member
    I have a 2002 GMC Sonoma ext cab with the third door and I was wondering how much weight it and the hinges can hold? I owned an ext cab toyota before this truck and I turned the cavities below the rear side windows into 10" sub boxes and would like to make the third door into a box for a 10" sub.
    Will the third door handle this project?
    Thanks in advance.
  2. Paladin
    Paladin Active Member 2 Years 100 Posts
    What is the weight of the sub-woofers you want to use? It seems to me that it should not be a issue for a 10-15 lb component.
  3. Rolling7z
    The sub woofer is 12.25lbs and I am going to guess I will have the same amount of weight in wood and fiberglass
  4. Paladin
    You might be starting to push it on weight. I suppose it might not be to bad if your not sitting around all weekend with the doors open.
  5. BurbanMan
    is the door used frequently?
