how to remove vent visors?
Discussion in 'General Chevy & GM Tech Questions' started by dabadas, Dec 18, 2009.
  1. dabadas
    dabadas Member
    i have a vent visor thats broken and was wanting to know how to remove the two sided tape without damaging my paint? any ideas? thanks
  2. 99'HEARTBEAT
    One of the Quickest & Safest ways to remove Adhesive without Damaging your paint is with a 3-M Eraser Wheel.You can buy them at Most Auto Stores.
  3. Mean_Green_95
    If u use the eraser wheel, don't use any pressure. The wheel will do all the work. If u put any pressure, it could burn through the paint.
  4. Viper
    Viper Rockstar 100 Posts
    heat gun as well will help remove the adhesive
  5. 93 Burboun
    93 Burboun New Member
    I used some goo gone and a straight razor. just be careful. came off like hot butter.
  6. XS ive
    XS ive Rockstar 100 Posts
    WD-40 will also remove glue
  7. dabadas
    dabadas Member
    how about denatured alcohol have to get from behind the counter at drug store
  8. dsrtne1
    dsrtne1 Epic Member 5+ Years 100 Posts
    Be careful with that...It's used to remove tint off of taillights. I wouldn't let that get near my paint.
  9. PapaJ
    PapaJ New Member
    Please don't put alcohol, wd-40, or other harsh chemicals on your paint. The best way to remove the glue is to use a heat gun and be really patient. Don't get it so hot it melts. After you get the big pieces off, use a 3m buffing wheel. As previously stated, don't use pressure with it, just let the wheel and your drill do the work. Again, patience is a must. I worked in a body shop for 3 years and saw a lot of paint ruined. If it's a factory paint job, it shouldn't be a problem though.
