    Join Today ~ It's Free
Hub Centric Wheels????????
Discussion in 'Lifted & Offroad Suspension' started by Jimbo74, May 7, 2009.
Random Gallery Photos
  1. Jimbo74
    Jimbo74 New Member 100 Posts
    i have no clue about hub centric wheels or even when they are required, can sumbody tell about em and when i would need to run em?
  2. Tight Lines
    Tight Lines New Member
    From what I understand, they are plastic washers that center the rim correctly when installed. The washer is usually part of the rim sale if needed. Maybe someone else can add to this but that is what I was told when I was going to change rims on my former car.
  3. adampaul1964
    adampaul1964 Active Member 1000 Posts 100 Posts
    Hubcentric just means that the center of the rim is bored to a precise diameter to fit the hub, this is used to ensure the rim is centered on the hub properly which eliminates vibration on large diameter rims, as opposed to the studs being used to center the rim. To ensure proper fitment you should run hubcentric rims on your '07 with the centerbore being 78.3mm and a lug pattern of 6x139.7, hope this helps. :great:
  4. Jimbo74
    thanks yall
  5. Pete95Sierra
    Pete95Sierra New Member 1000 Posts 100 Posts
    x2. good info once again :great:
  6. cascott325
    cascott325 New Member 1000 Posts 100 Posts
    i have never heard of that before. good question
  7. adampaul1964
    G.M. went to hubcentric rims for the '99 body style change, and also made the 2wd and 4wd able to use the same rim whereas before '99 the 2wd used a 5 lug pattern and 4wd used a 6 lug patern :glasses:
