Hyper Flash LED turn signal problem (help)
Discussion in 'Lighting Discussion' started by ffdsmokeeater, Feb 10, 2013.
  1. ffdsmokeeater
    ffdsmokeeater Member
    So I completed a full LED conversion on my 2010 Silverado over the weekend. All exterior bulbs are now LED (minus heads, fogs).
    However, I specifically purchased these LEDs that have the built in "canbus" base / load resistor so I wouldn't have to screw around with buying / installing additional load resistors.
    see here... http://www.carid.com/lumen/
    Well, low and behold, I installed all the LEDs and they hyperflash. Has anyone had a problem with this? Any suggestions?
    It's strange, when I activate the turn signal, it flashes at normal speed for 3 flashes then turns to hyper flash.
  2. SurrealOne
    The cleanest way to handle it is to replace your turn signal/flasher relay with a LED-compatible one. I don't know the model number on the one for the NNBS trucks but I know someone posted it here, once in the last few months. Gratuitous use of the search feature on this site should help you find the post containing it...
  3. sstoner911
    I am pretty sure the turn signals are controlled by the BCM on the NNBS style trucks...my )8 is anyway. I had the same issue ...had to add a resistor.
  4. redneck70
    redneck70 Rockstar
    I'm afraid if your still getting the hyper flash you'll have to go with resistors. The NNBS style trucks signal flash is controlled by the BCM, gone are the days of the good old flasher relays.
