I CAN NOT Believe What I just Read!!! (Burning Oil)
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Chevyguy69, Dec 12, 2012.
  1. stchman
    The 5.3L using oil is a very minor problem. My 2008 used about 1/2 qt every 5K miles. ALL engines use a little bit of oil between changes.
    GM has probably sold over 2 million trucks with 5.3L engines with AFM since 2007. If it was as huge a problem as people make it out to be, GM would have discontinued the engine.
    - - - Updated - - -
    I've never seen a Tahoe with a V6, as a matter of fact, I don't think Chevrolet has ever put a V6 in a Tahoe.
    - - - Updated - - -
    The 6.2L (L94) has AFM as well. The L9H 6.2L appears to NOT have AFM. The L94 engine is used in the Escalade. I cannot verify that the 6.2L in the Silverado has AFM or not.
  2. O'Brien
    O'Brien Member
    My 2012 Silverado CC 4X4 6.2L with 373 gearing comes equipped with the L9H non afm engine.As do the 4X4 6.2L Silverados with 3.42 gearing.
  3. stchman
    Did you get the Max Trailering Pack in your Silverado? IIRC that's the only way to get 3.73 gears.
  4. O'Brien
    O'Brien Member
    Yup. Mine is the Max Trailer Pack. However as far as I understand all of the 6.2L equipped silverados be it 2 WD or 4 WD have the non afm 6.2L. It is only available in Ext Cab or CC versions.
  5. stchman
    So the 6.2L AFM engines are in the Escalades and Yukon Denalis it appears.
  6. O'Brien
    O'Brien Member
    That's affirmative. At least everyone I've seen.
  7. Chevyguy69
    Chevyguy69 Member
    That is very true of how ppl take care of them. I baby mine and the maintence is like clock work. Now back in the day I was hard on them and only knew 2 speeds- wide open and stop! lol.
  8. stchman
    Do you have to run premium gas in that 6.2L engine?
  9. 1953bowtieguy
    1953bowtieguy Rockstar 4 Years 500 Posts
    When was back in the day, the 80s? ya i baby mine too.
  10. O'Brien
    O'Brien Member
    Yes. The L9H 6.2L calls for 91 octane or higher.
