I have a couple questions
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by BuckeyeBandit, Jun 23, 2008.
  1. BuckeyeBandit
    BuckeyeBandit New Member
    Nice site and hope to be a regular since I have a "sub" now. Its a 1997 Suburban 1500 4x4
    What does the "SLT Package" mean?
    Is it safe to pull a trailer weighing 3400lbs in overdrive? The manual says i can, but really not sure.
    I have a clicking type sound in the front end at very slow speeds...any ideas? Its louder in 4x4
    I really never worried about towing before because i had a old school SUB that had a big Bloack and 400 tranny. This small block with OD tranny scares me a little.
  2. tbplus10
    Pulling a 3400# trailer in OD should be no problem, I do recommend trailer brakes if you dont have them.
    Clicking sound from the front sounds like you have a CV going bad, take a look at the CV's soon they can cause damage when they go.
  3. BuckeyeBandit
    Thanks for the quick reply.
    It also has another problem, the fan switch for heat and a/c only works on high. I was wondering can you get only the fan switch you do you have to buy the cluster of climate controls?
  4. Crawdaddy
    fan switch problem is most likely a blower resistor issue. The low speeds always go out in them, it's a fairly common porblem. I wanna say a new one is rather cheap and it should be easy. If I remember correctly it should be under the hood right next to the blower.
  5. BuckeyeBandit
    thank you very much
  6. BuckeyeBandit
    Well i think i might have a crap truck. I went to drive it today and the windows would not go down unless the driver put them down. I checked the switch to lock the windows and it was on normal.
    Once again, any ideas...lol
