I just joined and need help
Discussion in 'General Chevy & GM Tech Questions' started by 1flyfisher, Jan 4, 2010.
  1. 1flyfisher
    1flyfisher Rockstar 4 Years 100 Posts
    I just joined and need help, 3.42 vs 3.73 gear ratio
    I am in the process of buying a 2010 GMC Savana AWD cargo can.
    I am getting the G80 differential and it will be AWD.
    I can get 3.73 or 3.42 gear ratio. I have no idea what to do here. I want good gas mileage and good performance offroad.
    What is the preferred gear ratio for vans, pickups, suv's?
  2. itsabowtime2
    itsabowtime2 Rockstar
    General rule, lower ratio (3.42) will yield better fuel economy.
    Now for a disclaimer :happy:; driving habits, maintenance, load will all play a part in your economy.
  3. 1flyfisher
    Yes I am aware that the 3.42 may give me a better gas mileage depending on how I drive.
    I am wondering what ratio is more of a generally accepeted gear ratio for pickups, vans, suv's. IF there is one.
    I won't be towing much.
    The salesman said the 3.73 would be better climbing hills.
    Does it matter which one I get? I will be driving this vehicle off road , dirt and gravel roads, snow.....etc
  4. 1flyfisher
    3.42 vs 3.73
    Oh yeah.
    This vehicle has tow/haul mode which is supposed to help prevent hunting between gears when climbing hills. I guess that would help with 3.42.
    Anyone have a 3.42? Do you like it?
    I live in mountain country here in the CA Sierra's at Lake Tahoe and high elevations... lake level is 6200 ft. I am generally driving at high elevations 5000 ft to over 7000ft, alot of 1-2 hour+ highway drives on U.S. 395 and I-80 to get to lakes and then off road for a mile or so.
    I MAY be buying a small boat 19' in the future. I may not.
    I drive off road quite a bit.
    Wash board roads, dirt roads, mud, sand, snow, hard pack snow.
  5. retired2001
    Most of the pickups with the G80 option have the 3:73 ratio, more for low end torque vs gas mileage. My new Colorado has the 4:10 G80 and I would just as soon had the 3:73s.
  6. 1flyfisher
    I am not currently towing anything. I am ordering the trailer hitch as I may tow a trailer or light boat in the future.
    I do live in some hilly areas and I am at a high elevations of 5000 to 7000+ with lots of hills.
    Vans are pretty heavy and I am perplexed as to what to do here.
    I read and article by a GM exec that said the higher gears really don't adversely affect MPG's. I said speed difference affect the MPG's. As in driving faster vs slower speeds affects MPG rather than if it is a 3.42 or 3.73.
    Nonetheless I am seriously struggling with the decisions as to what to get. 3.42 vs 3.73
  7. itsabowtime2
    My Tahoe has the 3.73. I am pleased with the performance. I get about 16-17 highway.
  8. tbplus10
    Go with the 3.73's if you intend to use the truck for these tasks, the MPG loss wont be a lot but the performance will make a difference off-road.
  9. 1flyfisher
    I found this article/interview with a GM exec.
    It is a good informative read on this subject of 3.42 vs 3.73
    This 1500 Van is 5000+ pounds and comes Standard with the 3.42 with the 3.73 available as a NO COST option.
    The 2500 (3/4 Ton) and 3500 ( 1 Ton) come Standard with the 3.73.
    The weight difference between the 2500 and 1500 is about 300 pounds and that vehicle comes with the 3.73.
    The 1500 AWD Savana has the 245/70/17 tires which are 30" tires.
    I was considering 255's.
    ANY ADVICE or Opinions would be greatly appreciated as I would like to hear others thoughts on the matter.
    Thanks in Advance
  10. Mr Dragon
    Mr Dragon Rockstar
    The 2010 should have the 6 speed transmission, so I would definately go with the 3:73, better toruque for offroad driving. If you use 4 Low, much the 3:42 will not grind it out as well. Just my preference and opinion.
