I need help on my flowmaster muffler install
Discussion in 'General Chevy & GM Tech Questions' started by SRALinQ, Sep 17, 2009.
  1. SRALinQ
    SRALinQ New Member
    Ok guys I have a 2006 silverado with a stock 2 3/4 inch piping. I bought a flowmaster muffler with a 2 1/2 inch inlet. I cannot find a step down connector pipe anywhere. So i was trying to find out if there is something I can do to make it fit without having to weld anything. Any advice or references would be great.:eek:
  2. Z71_guy
    check your local auto parts store and see if they rent exhaust pipe expander for that size, or call your local exhaust shop and see if they can get you a step down
  3. drkbluZ71
    drkbluZ71 New Member
    check autozone thats when i picked up mine when i welded up my flowmaster. they should have several different id. and od. of piping.
  4. SRALinQ
    SRALinQ New Member
    yeah i checked autozone and pepboys but they dont carry a 2 3/4 to a 2 1/2 step down
  5. 2wheelmudder
    2wheelmudder Rockstar 100 Posts
    get a clamp and smash the bitch down until you cant tighten anymore
  6. Mean_Green_95
    you can cut relief cuts into the stock pipe and squeeze it down to the 2.5" diameter.
  7. vncj96
    Me personally I would be leary to take what the factory had set-up and make it smaller, while it is only a 1/4 of an inch it could give you more restriction and rob you of some power or MPG as it tries to take what normally flows at one diameter and now take the same amount and force it into a smaller diameter, 2 1/2 inch is pretty common maybe try and sell it on craigslist and then get the correct size.
  8. SRALinQ
    SRALinQ New Member
    I did it
    We put relief cuts into the connector pipes and it runs and sounds like a beast thanks for the info guys:party:
  9. Mean_Green_95
    SWEET, he used my suggestion, lol. J/J guys.
  10. crash_42
    crash_42 New Member
    my adice take it to a shop and have them weld it in.. 25 bucks for them on mine
