Identify this heater core valve - 97 Tahoe
Discussion in 'General Chevy & GM Tech Questions' started by BlackHawk99, Apr 27, 2009.
  1. BlackHawk99
    BlackHawk99 Member
    Do any of you know what this part is for? It was leaking badly on my 97 Tahoe. It looks like some sort of flow valve. It's in the middle of the heater core hoses. There's one vacuum hose coming off the side that plugs into another diaphram mounted on the firewall.
    What would happen if I just elimate this thing? If not, what's it called so I can get a new one? I was hoping it could be a HELP part, but I doubt I'll be so lucky!
  2. Dr_Zero
    You would probably have heat blowing all the time.
    You could disconect the heater hose from the core and to each other that would bypass the core till you go the valve, since its summer you probably wont need any heat or defrost.
  3. GaryL
  4. BlackHawk99
    BlackHawk99 Member
    So funny...I found it on AZ's website shortly after I started this thread. I'm leaving in about 20 minutes to go pick it up.
    All the pics I have of the 78 are older (like three or four years ago), but I"ll start a new thread in the off-topic forum!!
