Idle Control
Discussion in 'Chevy C/K Truck Forum' started by bradyjames, Apr 14, 2014.
  1. bradyjames
    bradyjames New Member
    I am on a quest to help the groundskeeper at my school (UC Riverside) fix his 1988 Chevy C1500 5.7 liter V8 w/ a manual transmission.
    Truck starts up fine. During the first ten minutes when you step on the accelerator, the idle surges as expected, but then it takes a while for it to settle back down before you can hear a normal idle speed. What should I be looking at? I jumped the computer with a paper clip and no codes flashed. The shift light for the transmission lit up, but according to the owner, he has had no transmission issues.
    Any help or direction is much appreciated.
  2. RayVoy
    Brady, do you know if that engine has a carb, or uses throttle body injection?
    Either way, the throttle linkage may need some lub.
  3. bradyjames
    Hi Ray. It has a throttle body injection. Is there a specific lube I should use or will some WD40 do the trick?
  4. RayVoy
    Brady, do you know if it uses mechanical linkages between the gas pedal and the tbi (I think it does).
    I'm guessing the linkage is just slow to return to idle, it could be a little rust, it might be a weak spring. I think WD40 will work for ya. I don't like to have the engine running when I'm spraying WD40, just incase it gets sucked into the engine. Spray the linkage with the engine off. Also, look at the gas pedal hinge, it might be rusty as well.
  5. bradyjames
    Thanks Ray. I will give it a try and post back soon.
