idler and pitman keep going out on my 04 z71
Discussion in 'General Chevy & GM Tech Questions' started by usetaboost, Apr 20, 2012.
  1. usetaboost
    usetaboost Rockstar
    I replaced both 3 yrs ago and have barely put 15k on the truck since then. I don't do any off roading with it and is 3/4 highway driven. I do have a set of 20s that I put on during the summer but I doubt the bigger wheels could be causing it. What brand or fix is everyone using? THese parts are kinda spendy at 100 bucks a pop. I'd like to do it once and be done with it.
  2. moogvo
    From what I understand, that is not all that uncommon. Is the diameter (height) of your tire bigger than stock? Are they a lot wider? and the big one... Do you keep your suspension parts lubricated like you should?
  3. dsfloyd
    What moogvo just said. Plus what brand did you replace them with (aftermarket or stock with warranty). Look into heavy duty aftermarket ones. NAPA usually has a couple different lines with, of course the most expensive, being a lot beefier than stock. Moog is also another quality heavy duty suspension parts. 102004 50014 2014023 102004 50014 2014023
  4. moogvo
    Absolutely! :great:
  5. usetaboost
    usetaboost Rockstar
    Yeah I usually grease the front end every other oil change. If I go with moog parts next time will this solve the problem? I could do a lot of other stuff with 200 bucks so I don't wanna have to do it again in another 2 yrs. The 20s are same size as the GM 20s
  6. Blazer454
    Blazer454 Member
    Your 04 didnt come stock with 20's though. On 99 to 07 classics the idler and pitman get worn prematurely buy putting annything bigger than stock wheels or tires, more so seen from 20's and up. I wouldnt go with napa parts, they arent as good as they used to be and are overpriced for the quality of part you get. Moog or raybestos make good chasis parts and both have heavy duty upgrades. You should be greasing your steering components at least every oil change. They cant get enough grease. Try searchingh online too because there are other brands that have made chassis parts that are upgraded for lifting and 4bying these trucks
  7. usetaboost
    usetaboost Rockstar
    ok thanks for the advice and I'll look into it.
  8. Brad Preece
    Brad Preece New Member
    Alot of the newer ones with 20s come with a rack and pinion. The truck you have isn't designed for that much resistance when turning. You might not think its alot on those parts, but it will and has shown its too much as far as longevity is concerned.
