Im recharging A/C, bypass pressure switch?
Discussion in 'General Chevy & GM Tech Questions' started by User Name, May 1, 2009.
  1. User Name
    User Name New Member
    Hi. I have a 93 sierra. I need to add r-12, i am vacuuming it down now. Is there a low pressure sensor I need to bypass. Or will the clutch kick in as I add Refrigerant?
  2. Crawdaddy
    You sure it's R-12? If so, perhaps you should consider upgrading to R-134a. It's alot cheaper and easier to get. That being said, you should be able to just dump it in on the low side and the compressor should kick in and pull it through. Good luck!
  3. User Name
    Never mind. It was the switch on the accumulator. Shorted it. Thanks anyway.
