Installing Aftermarket Radio
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by suburbanboy, Jun 1, 2009.
  1. suburbanboy
    suburbanboy New Member
    I am trying to install an after market radio and system in my 1997 suburban. I have everything installed properly (amps, cross overs ,et)c and when i plugged the new radio in only my drivers side front speaker goes on. Is there a factory amp or something in the truck I am missing? Wiring harness is all plugged in correctly. Speakers work fine with factory radio unit plugged in. Any ideas would be appreciated... Thanks...
  2. unplugged
  3. SuburbanSS
    SuburbanSS Member
    Did you buy a harness to plug into your factory harness then into the new radio?
    Did you splice the factory wires?
    Do you have an external aftermarket amplifier?
    Are you replacing the stock speakers?
    Need a little bit more info and I'll be able to help you a bit better.
  4. suburbanboy
    Thanks everyone but I figured it out. It was the factory amp under the dash that was causing my problems. Took it out and all is ok...
  5. Bredin
    Bredin Rockstar
    Where did you find the amp under the dash?
    I'm having the problem that I am only getting sound thru my front speakers, no sound thru the passenger door speakers and only a high tune sound from the speakers in the back in the roof...
  6. YotaLuver
    YotaLuver Former Member
    Amp location
    My Delco factory installed amp was under the blower, passenger side, in a blck box. I always wondered what was inside there and found out when the amp died.
