Installing brake controller
Discussion in 'Towing & Trailer Tech' started by Conlan Rose, May 21, 2012.
  1. Conlan Rose
    How do you install a brake controller on a 96' Tahoe.
  2. Crawdaddy
    It's pretty simple. There should be a positive, negative, brake switch, and trailer brake wire coming out of your controller. The positive needs to go to an always-on fused circuit, negative to a good ground, brake switch trigger to the cold/switched side of the brake switch, and the trailer brake wire going to the trailer brake pin on the 7-way connector. Hardest part is getting the brake switch trigger.
  3. KidHauler
