Instrument panel lights went out
Discussion in 'General Chevy & GM Tech Questions' started by johncc, Sep 24, 2008.
  1. johncc
    johncc New Member
    I have a 99 silverado and my instrument panel lights will not come on when my headlights are on like they normally do. They do come on however when I turn my overhead cabin light on. Any ideas?
  2. speeddemon31176
    speeddemon31176 New Member
    Could be a bad headlamp switch. Actually I would say that is the problem but it cooouullld be something else.
  3. retired2001
    I received a letter a while back about a "class action" suite about dash gauge, light, etc. failures for a group of trucks. Mine didn't have the problem or meet the criteria so I threw the letter away. You might check with the dealer to see if yours is covered in that group. GM was supposed to take care of failures, but I don't remember the particulars. Good luck!
  4. Springthing
    Is the chime still working when you have the door open and the lights on?
    If not, then check fuse #9 (may be different for you) in the fuse cluster inside the cab.
    I just had the dash lights go out two days ago and noticed it because I had my door open with the lights on and the key in the ignition and didn't hear the annoying dingdingdingding of the chime. Checked fuses and that one had burnt out. All fixed now.
    Good luck!
