Intermediate Steering Shaft Lube Procedure
Discussion in 'How-to Guides' started by dwill3015, Jan 22, 2009.
  1. leftywoody
    leftywoody New Member
    The pencil shows the opening where you stuff foam or some other expanding substance up in there . that will stop the grease from travelling down and out the tube shaft .
    1 person likes this.
  2. Doug Dennison
    Doug Dennison New Member
    I wondered about that. Mine's the smaller one, I think. The tunes are about a foot long, and maybe 1-1/2 diameter. Not one of those YUGE ones. I'll keep adding. The clunking isn't awful; just annoying. Only at very slow speeds or when turning the wheel while sitting still.
    Thanks again!
  3. leftywoody
    If you don't block the end of that tube , shown where the pencil is stuck up in there, you will get grease going down the tube instead of up the tube where it will do the most good . That may be why it is still clunking . You should plug that hole with some cloth or some tin foil or foam rubber rope like was suggested . At least you will save you the mess of it oozing out the tube at the bottom .
    Doug Dennison likes this.
  4. Doug Dennison
    Got it. What about a squirt of expanding foam insulation? Any harm in using that? Seems like that would seal into those ridges and not fall out once it cures.
  5. leftywoody
    I would think it would but you would only need a quick shot of it . You just need to create a plug , not fill the tube with too much foam .
  6. Doug Dennison
    Yeah. That's what I was thinking. First, I gotta clear some grease out by that hole at the bottom. It's there all right. Thanks again for all your advice.
  7. Doug Dennison
    Eureka! It looks like it worked. I had grease about coming out of the bottom of the tube, so thought the expanding foam wouldn't work. Instead, I stuffed a pretty good-size piece of sponge up there. Then I added a few more shots of grease, and saw it coming out the bottom. I pushed the foam back in, drove the truck a couple times over the next day or two, and the tested it again - no clunking. I might add a bit more of both sponge and grease, but it's MUCH better.
    Thanks again for all your help!
