is 210 a normal idle temp on 07-09 silverados?
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by george b, Sep 23, 2009.
  1. george b
    george b New Member
    isn't that boiling?? mine reaches 210 once warmed up. is that normal?? my 98 chevy is more like 150.
  2. unplugged
    Antifreeze and a pressurized cooling system raises the boiling point of water.
    Here is a chart of the boiling point for anti-freeze/water mixes.
    Add a pressure cap on the radiator and with a 70/30 antifreeze mix the boiling point rises closer to 270.
    210 is not a problem. If you want a lower idle temp you could try a 160 or 180 deg tstat.
    Be advised that emission equipment is designed to operate at higher temps so a lower temp tstat may cause other symptoms.
  3. starsilverado
    starsilverado Rockstar 100 Posts
    210 is the normal operating temp.
  4. Tdaz250
    Tdaz250 Rockstar 100 Posts
    Yeah i think thats normal for the new trucks. Both my buddies denali and silverado are right at 210 when i drive them about, and there both 07+ so i'd say its normal. And my silverado stays around 180-190 usually.
  5. jow003
    jow003 Member
    this is a slight change in subject but how hot is too hot for the transmission?
